Man you can rebuild it yourself. Novaderrik has the right idea. Here is what I did (just rebuilt mine)
Pull the damn thing out.
Tear it apart to just a bare block, take the pistons, rods, crank and block to a machine shop. tell them to check it all out, and do what they ask.
Get it all back, depending on if and how much your crank needs to be cut, order main and rod bearings accordingly. (Mine was a stock rebuild with another crank, it was turned 10/10 so I ordered 10 under bearings all around. I had the block line honed, bores honed, crank /rods balanced, hot tanked and....thats it. I plastigaged the mains and a couple rods, made sure everything was fine and dandy and put it back together very carefully and made sure everything was PERFECT.)
Before you put it back together, make sure all of the "flash rust" is removed from the block after they give it back to you after being hot tanked.
Make sure the crank spins nice and neatly inside of the journals with bearings (line honed or not do it anyways)
If all is good, put it back together, make sure everything lines up nicely, take your time on it, and put it back in the car. Make sure cam sensor is set properly and heads are torqued correctly. Also make sure to check the thrust play on the thrust bearing. wack it a couple times back and forth to seat it.
This is what I did with my car, VERY SIMPLE procedure, anybody that has a basic knowledge can do it, and if you don't understand something call someone that knows about these cars or look online.
Fired mine up, 20 psi at hot idle with 10w30, stock cover and an oil pressure plate on the housing (it is time for me to get a timing cover, but as of right now oil pressure is great)
The only issue I've had with it is my transmission took out the thrust a couple times since rebuild, have figured out what the problem was and already fixed it. It had nothing to do with the machine work or assembly.
If a 21 year old kid can do it, you can do it.
The only thing that I would be concerned about, is that it is a H/A motor. same interals, quite a bit different on the R&R procedure like Nick previously stated. Make sure to take LOTS of pictures and number everything accordingly, putting bolts and nuts/accessories into seperate grocery bags.
