How fast with 83's?
325DR
My injector duty cycle is hitting 100% running 10.0x's with 72lb injectors. Are 83's enough for mid-high 9's or should I go to 95's?
Thanks Chris.
Which is going to limit me first:
83's or a double pumper (walbro 340's)?
:confused:
I have gone 9.83 with stock fuel lines and a double pumper.
I went 9.50's with 83's stock fuel lines and a ATR double pumper. My duty cycle was 88 to 90 percent. I have stepped up to the 96 lb injectors since then.
Thanks guys.
Dave - do the 96's seem harder to tune? Is low rpm/idle still acceptable?
The idle is fine, I had to rework some of the numbers on the tip in. If you have to buy new injectors just go with the 96 lbs and be done for a while.
Are you still using the double pumper?
Its good to know, many people under estimate how far they can go.
top gun said:
Since I planned on running quicker than 9.50's I stepped up to a Weldon 2025.
