I have a transmission that occaisionally will start off in second gear. I believe the problem is my minimum TV pressure is too high at 140 psi. I do not like the soft shift feel from backing off the TV cable so I am wondering if there is anything else I can do?
I am running a Transgo shift kit and the purple pressure regulator spring in the pump along with the .500 boost valve and reverse valve that comes with the kit.
Would changing the PR spring back to the stock PR spring help or would it introduce a new problem with the bigger boost valves?
A couple of other thoughts I had were to put the stock TV spring back in and/or remove that small spring transgo has you put in the 1-2 shift valve (never seen this in any other kit and not even sure what it is supposed to do).
