v6turbojunkie
- Mar 14, 2004
I need to know everything about the install of an adjustable prop valve. I would assume that it needs to go on the front brake lines since I need to limit that pressure and shove more to the rear brakes. Do I put it between the master and stock valve or after the stock valve somewhere? Does the stock valve get reused? I noticed in summit's website are single inlet/outlet but had some choices about hole sizes (1/8, 7/16, 10X1.0) which one and do I need adapters? What brand?
If anyone can help please be thorough. Not to be a total pain but I want to make sure I do this right. Had a bad experience with shoddy brake job once and skidding down a country road at 60+ mph in a vehicle upside down sucks.
