Alrighty, so I got around to this. Again, my coolant was really clean still, but my car was running around 190 with the AC off and 200 or so with it on. I trained all I could, pulled the T stat, put it on the stove in hot water to make sure it opened properly. That was all good. I then reattached the neck without the t stat and piped compressed air through the upper radiator hose. I got quite a bit more out. Probably about 3 gallons total. I filled it back up with distilled water and RMI-25. Thanks for the advice Nick! I'll return the water wetter. I jacked the front of the car way up so I could burp the system. Got it to operating temp with the heater on and ran it at 2000 RPM while filling her up. Buttoned it up and went for an 80 mile drive today. It stayed at 165 -170 AC off and 175 with the AC on. I'm a happy camper.......except the AC went out when I was around the corner. After a little troubleshooting I found that the magnetic coil on my compressor clutch went out. Note to everyone Stay the Hell away from the AC Delco replacement compressors. I have a spare that has a good clutch on it. I may just swap them out if I can do it on the car. I guess if I didn't find some gremlin to chase every time I drove it, it would not be a turbo Buick.
