D Darkside New Member Joined May 25, 2001 Mar 9, 2008 #1 How do I check the egr solinoid? Anyone know how to check this part to see if it has gone bad?
T turbojd Well-Known Member Joined Dec 27, 2005 Mar 9, 2008 #2 You can check it with a mityvac(vacuum pump) and see if the diaphram holds vacuum.
R rob350 Member Joined Apr 23, 2006 Mar 9, 2008 #3 I got ahold of a mitty vac, and my diaphram does not hold vac. very long. I have the EGR programmed out, but im assuming this is causing a vacuum leak? Sorry if I hijacked the post.
D Darkside New Member Joined May 25, 2001 Mar 10, 2008 #4 My EGR is fine. I am asking about the the electrical egr solinoid mounted oin the valve cover?
