The deck is higher and the oil pan most likely isn't baffled. You'll also have to fab up some sort of turbo drain and I think a 79 is odd fire so the crank won't work. You'll also need a TR specific hub and flex plate along with the crank
Moral of the story, it's most likely not worth it when 109's can still be found on the cheep cheep
