I m trying to hook up boost, water temp and air/fuel ratio gauges and for some reason I am having WAY to many problems.
First, the boost gauge only is reading the vac and hen I boost it only goes to 0..no more. It is hooked up to what i think is the manifold vac hose )not sure though). Is this wrong? Is there a better place?
Second, I have to sensors that i believe are for my water temp. One with one green wire out of it and the other with a black wire and a yellow wire coming out of it. What wire should I tap off of to get a correct reading?
Third, When i hooked the air/fuel gauge up it worked BUT my car ran like a piece of $#!%. It was always jumping from rich to lean and when i gave it gas it would stay in the rich zone.
Any help on this would be awesome. I would hate to think it would require a NASCAR mechanic to install these.
