Turbo__Tim
One heck of a Tim!
- May 25, 2001
Actually I'm hooking up a 'speed valve' for alchy injection. I assume that it would be safe to hook it up just like a seventh inj.?
I plan on running it off a hobb switch. Positive voltage through the hobb to the pulsing solenoid (speed valve), and the ground will tie into to the ground side of the injector.
If that's right, and that is all there is too it, does anyone know what pinout I could use instead of cutting into the harness? It looks like D-14 would work, if I'm reading the diagram correctly.
http://www.gnttype.org/techarea/images/wiring_images/ecm_turbo.jpg
