Holley Pressure sensor w/FAST XFI
you will need to run the signal wire to one of the analog sensor inputs, and provide power and ground to the other 2 wires coming off the sensor pigtail
how do you have the fast wired?
where can i pick up the 5v ? is the FAST sensor wired the same or just plug n play ? havent installed the FAST yet , just in the begining stages of putting it in . This is for a v8 so im not using any factory v6 wiring .thanks for replying .
If you are only running the sensor to the Fast and not a guage, you can plug all three wires into the ANALOG plug on your FAST harness. Pin A signal, Pin J power, Pin K Ground
THANKS !!!!!!! thats exactly what i want to know !!!!! i was told i would have to splice into the map wire for 5v source . that didnt make sense to me .
