Planning on getting a EFI system, have been comparing DFI vs FAST (like many others....) and now I have a new player in the game, the commander 950....
Why arent you guys using it? All I see is FAST and DFI..
It has a lot of cool/good stuff like
Internal data-logger: Allows user to data-log without a laptop in the vehicle. Will log between 24 seconds and 2.5 minutes depending on sampling rate. Logs up to 13 inputs including two spare 0-5v inputs. Beneficial for sanctioning bodies that do not allow for a lap top to be in a race car or for race application where use of a laptop is difficult; such as a dragster.
Programmable load scale: Allows for the 16 load points to be defined by the user whether speed density or Alpha-N is chosen. Allows for resolution where it is needed. Great feature for supercharged and Alpha-N engines.
Programmable inputs and outputs: Allows some of the inputs and output lines to perform different functions, such as timing retard, a wastegate control, RPM-activated switches, etc.
Programmable O2 voltage: 4 x 4 matrix allows user to program in target closed loop O2 voltage from 0-5 volts depending on RPM and engine load.
Programmable O2 compensation limits: 4x4 matrix with separate (+) and (-) limits allows user to define closed loop compensation limits.
O2 signal inversion: This feature lets you run an aftermarket wideband O2 sensor or a regular narrowband O2 sensor with the Commander 950. Many aftermarket wideband sensors have an output of 0-5 volts from rich to lean and a regular sensor has an output of 0-1 volt from lean to rich.
Wideband O2 operation: The previous three features make it possible to use a wideband O2 sensor and amplifier with the Commander 950 and run closed loop or use it to datalog actual A/F ratio during a run.
Noise block: Allows the magnetic input to be used in noisy environments (such as inside a distributor cap)
RPM to 12750: Allows for peak engine RPM of 12,750 as compared to the standard software of 8,150 RPM.
Deceleration Fuel Cutoff: Shuts fuel off when decelerating for better emissions and fuel economy.
Timing trim vs. Coolant temperature: New table to add timing vs. engine coolant temperature.
Fuel pulse strategy: Allows selection of firing the injectors once per revolution or once every two revolutions. Allows for better idle control with very large injectors.
AC input: can raise idle speed when AC is on
/N.
/N.
