Don't waste your $$ on the Kenne Bell design go to Advance Auto or NAPA and get the new thrust plate which is the same thing for $15 and you will not need to do any machine work to install it like the KB setup. Frank
Yes on the front covers i get where the hv part is moulded to the cover so its not an add on piece. But the style hv cover where the hv part is added on like an extension??? I'm not sure if the supplied bolts are long enough for that or not. If not you could get the bolts locally from a hardware store. Frank
