My front A-Arm bushings need to be replaced, (thanks to the close proximity of the downpipe), and I do not want to use polygraphite or any type of poly for that matter. I would like some harder-rubber bushings than stock, is there a GM part I can use? Like the rear 1LE Camaro ones? I have a downpipe bushing heat shield that I will be installing to avoid damage to that bushing in the future.
So.. are their stiffer RUBBER front A-Arm bushings available?
TIA
TIA
