help!!
trbo6gn
ok here is the deal. when i start to build boost it builds very slow to about 10 pounds and when it gets to that 10 lbs. it starts to buck and feels as though it is hitting the revv limiter. almost as though it is cutting out on me. someone told me it could possibly be a bad chip. any ideas and if soo can i just put back in the stock chip with the 009 injectors for the 4 days that i will be on my triP?
Don't run a stock chip with big injectors. It will peg out the BLM's and INT's making it run pig rich (ECM can't remove any more fuel). Dumping that much fuel into the cylinders is not a good thing. Washes down the rings and gets down in the oil thinning it out (can cause possible bearing failure).
Send some T-link files and information to a knowledgeable person and see if they can see anything odd.
