ok here goes read this post then tell me how to get my tranny away from motor
http://www.turbobuick.com/forums/showthread.php?s=&threadid=122394
the only other piece of info is the fluid level was correct before prob so all i can figure is converter dumped all fluid into tranny because when i pulled dip stick to pull tranny it dumped probably 3 qts out of hole where tube goes in.
i'm thinhing probably pump and or input shaft.
anyody got any idea how to get tranny to come loose from motor besides obvious unbolt converter wich cannot be done because motor wont turn because converter or input shaft is jammed.
