I believe my original starter need to be replaced. The car is not turning over as I crank the key. As I"m trying to remove this large engineering marvel we call a starter, I want to make sure it is the problem. I checked the battery and it is fully charged. I did measure voltage to the wires at the starter using a volt meter and was good(I think?). Are there any fuses that I should check? I did use the hammer thing and nothing.
If it is the starter, I was able to remove the bolts. Does the transmission lines need to be removed? I was able to remove the cable from one of the leads but can I remove the starter before removing the other wire (for easy access)?
As for starter types, what additional work do I have to do if I purchase the mini starter? how about the LT1 starter? How about the LT4 starter?
I've been working on removing the starter this morning and I just need a break. Any help is GREATLY appreciated.
Thanks,
Thanks,
