11secondgs
- Jun 6, 2003
3 questions.
1) why do I need to supply 5V power to the C terminal of the map sensor? What does this do? Is there a better source than the TPS sensor? I have an analogue car I converted to GNX dash.
2) on the pump wiring. My fuse block in the alky kit from razor is labeled "+" "-" but I do not see an "o".........Does the "o" refer to the two screws on both sides of the "+" and "-".
3) can someone briefly explain why the violet wire hooked up will help me spool on the transbrake? Basically, If I launch at 10 PSI, do I even need to worry about the violet wire yet?
I want to have this up and running before Friday. Looking to run 26 lbs of boost, What initial tuning should I set on the PAC, Pump, and external controller.
Thanks in advance to you alkyholics who can help me through this. Can't wait to join the ranks.
