Just changed heads on my car got all the problems worked out but the high blm's.
I have zipp tied all the vaccum hoses not seeing any leaks that route.new header gaskets seem to be sealing fine so prob not exhaust leak.
Here are the symptoms for you doctors.....
BLM's start at 142 at idle and go to 151 at wot
Car has a slightly rough idle at lower rpm's
After pulling the plugs they all have a light white/grey look
Had to max out the TT chip in order to get a 10.8 afr at wot 20psi
Ever since I pulled the intake and removed the fuel pressure reg the fuel system doesnt hold pressure that long anymore.Use to hold 40lbs for weeks,now maybe 10min.
So could this be a stuck injector? Seems like a deff fuel issue since the change in the sytem not holding pressure anymore and the plug color.
