I've been tuning my FAST on my turbocharged firebird. It has a T72 on a 383 (www.spooled.cz28.com). I've got everything pretty much tuned up to 15 lbs or so but I constantly have a big rich spot when taking off. When i log a pass, right when the boost comes up, the AF goes down. Both are very steep curves. They make an X. Actual AF will go down to like 9.5:1 while the target is up around 11.6 or so. It does it for about 1 to 1.5 seconds then it comes back up to the target ratio. I have no idea why this is happeneing. The O2 is telling it to add fuel. This is why it's happeneing but i can't figure out why the O2 would be telling it to add like 15% fuel or more (which is what it's doing). I don't know if this is a common problem or what. I just thought i'd throw it out there and see if anyone has experienced the same thing. I'd say it starts at about 100 kpa and it's back up to the target AF ratio at about 160 kpa. Should i log any other sensor that you might think could be telling hte O2 to add fuel? Any help would be greatly appreciated! THANKS!
