jarredsoon
- Aug 9, 2007
I am installing a 200-4r from my turbo Buick into my 81 corvette. I hooked up the tv cable to the trans by pushing the hook through the eyelet of the tv cable, then screwing in the 10mm bolt to hold the cable down. That was yesterday. Today I went to hook the tv cable up to the throttle linkage on the carb and the tv cable won't pull out. I moved the adjuster in and out but the cable still won't move. Next I removed the 10mm bolt holding the cable onto the trans, pulled up on the cable sheath and can not see the eyelet end of the cable. It is stuck deep inside the transmission.
What do I do to fix this??
I don't want to pull the pan, it has never been off and I know nothing about transmissions.
