Help!! Transmission check ball question
onefastjackass
I started installing a manuel style trans brake in my car and when I pulled the seperator plate a couple of the balls got away. So the question is
What is the location of the checkballs above the seperator plate in a 2004r ??
If anyone has pics it would be an even bigger plus.
I did a search but on an earlyer post and it would not let me view an attachment that has the pic.
It'd be best to get that info from the valve body manufacturer or post what brand valve body you have. Checkball locations will vary with different design valve bodies.
Well it is a stock brf transmission original for my 1987 gn.
I am installing a stage rite style brake so I am reusing the original valve body.
Don't know if that answer the type but if I need to I will get the numbers from it in the morning.
Kevin
