Hi
Does anyone know what would cause a 1700-2200 RPM stumble/hesitation/shake in my 1990 Toyota 4Runner with a v6 & 5speed.
The hesitation is really noticable when I am justs cruising along in either 3rd, 4th or 5th gear... and once the tach hits 1700+ RPM. I usually have to downshift to a lower gear. It idles & runs fine under 1700 RPM or above 2200 RPM. When it shakes, the tach RPMs stay steady, it doesn't fluctuate!!!
The odd thing is the stumble/hesitation does not occur if I am going through the gears... or if I am at 1700 or lower RPM & step on the gas... it will rev through to 3000+ RPMs with no problems. And being in the GREAT WHITE NORTH, it does not stumble or hestitate at 2000+ RPM idle on cold starts either.
The hesitation does not happen all the time, but it is becoming more frequent. I've changed plugs, wires, rotor & cap, O2 and EGR but that hasn't made a difference!!!! There is also no code or engine light!!!
Any ideas, suggestions.
TIA....dave
TIA....dave
