Probably a break in the window line. Check voltage/resistance at each line. Check a Chiltons manual they say how to go through the testing/troubleshooting.
Sorry Im kinda vauge, I've only had to do it once.
check for power at driver side of rear glass. use voltmeter. you should have 12 volts to connector at rear glass if you have power there you might have a bad connection. take voltmeter and put positive on one side of glass and negative on other side of glass at connectors where wires hook to glass . if you have power at one side and not the other you have bad connection or break in wire . best thing would be to get a wiring digram. good luck
