Help me with my 95 Roadmaster HVAC!
rob350
Hey guys,
Need some input here.
My blower motor stays on when I turn the car off? :confused: Blower control module?
Rob
Is it some kind of computer control climate thing? No telling what the module is telling the switch to do. Break out the meter and follow the wire(s). There could be a stuck relay/bad switch or the module could be bad. Do you have a wiring diagram? Might try to look one up or get one from one of the part houses.
I had the same problem on a 1994 Buick Park Ave, the blower motor would run with the engine off. I replaced the blower control module and it fixed the problem. I did check the blower relay first, as that was easiest to see and fix, but that wasn't the problem, the module was the culprit!!
