crownvic96
- Jan 31, 2005
ok this is going to go on an '87 GN. its going to be a daily driver. with a few passes at the track just to get it dialed in.
mods it has now or will have when i order the turbo. i figure if everything goes right i should be ordering the turbo around late may early june depending on weather and my schedule.
stock long block
4" CAI from buick GN, 3" MAF,3" maf pipe, trans+, 3" up-pipe, PTE stock location intercooler. 72mm throttle body, ported upper and rjc power plate. mototron 60/65 high z injectors, adj fpr, racetronix hotwire and walbro 340 fuel pump. rjc billet pulley set. turbotweak chip. rjc and greddy electronic boost controller. TH3"DP with stock wastegate, test pipe, ATR 2.5" SS exhaust.
stock transmission(if it lasts, if tranny lets go i'll get a upgraded 2004r with a higher stall lockup torque converter)
suspension is bilstein shocks, replacement stock height moogs, HR parts lower control arms and anti-sway/roll bar, removed pinion snubber, dual air bags, 275/50/15 drag radial. trunk brace and front brace.
the one big variable i don't know about is if i want to put alcohol on it. right now i'm leaning toward yes. but if there's a turbo that would have enough flexibility to handle some extra boost with tha alcohol that would be great. if not what turbo's should i look at for having alky and not?
money is not really of any concern either. i just want the best turbo to match what i have.
stock long block
