Help me pick a 200r4 for my v8 cutlass.
V6UnderPressure
The Artist FKA Scott4DMny
Im reaching out to my fellow members here to get some help with my other project. I have a cutlass 442 that is getting a built zz430(430hp 430tq Chevy small block 350ci). It has a 3.73 rear. I was going to put a fresh extreme automatics stage 2 BRF trans in there. However, I have been doing some reading that BRFs shift around 5200rpm and that its not ideal for a v8? I want to shift at 5500. I have read posts that the BRF is only good for turbo Buicks and that I should get a Monte SS trans(CZF I think?). Or do I have my KZF built? Im just going to stop there since I am a dummy to transmissions and would just like to hear your recommendations.
Help selecting a non locking converter would be appreciated as well. :)
If you want 5500 rpm shifts I would make that clear to the builder along with the fact you are using 3.73 gears and the zz430 . Shouldn't be a problem.
Who ever is building should be able to reccomend a converter too.
Give Dave husek a call anything you need for the 200 he will steer you in the right direction.i have his billet 200 in my car with a different valve body.
