I replaced the little hoses to the heater core, and also took off the lower radiator hose but put it back on when I decided to leave the oil sending unit alone. Obviously the coolant had been drained during this procedure. I refilled the radiator and 24 hours later I see coolant dripping off the crossover pipe. I think it was also dripping off the starter. I go inside the car and there is a small amount of coolant on the passenger side rubber floor mat. So does this mean the heater core is leaking? Would it leak both inside and outside of the car? And what could have caused it? I haven't even started the car in 2 weeks as I also am installing Casper's engine harness, oil pan gasket, etc. etc. Could I have broken one of the little pipes on the heater core when I was removing the hoses? Even if I did, the pipes are up high and as I said the engine has not been started. Thanks guys and gals.
