If someone could shed some light on this one i would really appreciate it. I have an 86 T-top GN with about 90k. It has a mild chip from about 7 years ago, (i bought it in march 07) auburn posi, 26 or 2800 rpm redline converter with what feels like some good internals in it. I have a pro comp ultralite tach, boost, temp, oil, voltage, and fuel gauges, caspers knock gauge and a scanmaster 2.1.
Ok, so the problem is for awhile after i bought the car it would boost, then after about 15psi it would make a loud popping sound once twice or a few times depending on if i kept my foot on it long enough. when it makes the 'pop' the boost gauge drops then comes back up. i changed wires to Taylor 10mm, replaced my TPS which is set at .42 at idle. after screwing with it it quit doing it. now a year and half later its back. the car will boost about 19lbs. in first gear and i have noticed by feathering the pedal that when my fuel pressure guage dips to about 38lbs.( i have it set at 52PSI with no vacuum) is when this occurs ...... someone help, i'm no dummy with engines but not really educated on "our" unique gm design just yet
