I need you guys! My car is acting stupid! I will start from the begining: I was driving on 3 gallons of fuel, I pulled into the gas station and poured about 25 bucks worth(which we all knowe aint much). Well I pulled off and I went to step on it the car began to pull and at about 6lbs fell on its face like it ran out of fuel. I went home and parked it assuming it had gotton air in the line from being so low. The next day I went out and got about 2 blocks from the house and it did it again this time without stepping on it. I called around got different opinions: I changed coil pack and module, I changed mass air, plugs. Couple days didnt do anything, figured its ok. Went to the track and all with no problems.
Couple days later going to work same thing. I watched the millivolts and they dropped big time! I figured maybe the pump?
Called around again was told that wasnt it or it would do it all the time. I have my chip set for lean cruise figured maybe the chip was acting up and engaging lean cruise at the wrong time or something, took the lean cruise off and on the way home the weirdest thing happend!
I got to the light by work and while waiting the idle kicked up real high! I pulled off and as I was driving I could hear little misses, I watched the millivolts and they were very low. then It cleared up on its own. I got home and when I put the car in park the idle jumped up to like 1900!
I dont know what to try next!!!!!!!!!!
How do you know if your chip is going bad or your computer???
PLEASE HELP BOUT TO SHOOT IT!!!!!!!!!!!!!!!:frown:
