Did a WOT run 23-23lb boost, some retard, let off the gas engine starts to run rough,,,BLACK smoke coming out of tail pipe.
Things I've done or changed: Chip, put know good one in, really nothing wrong with the one that was in there,no help,,,change ECM to spare good one, no change,,,took MAF out, cleaned it, put back in, no change,,,,car wants to run really rich, black smoke,,,when MAF wire removed it runs a litte better, get NO codes except when maf is unhooked then I get code 34+51,,,,,,,,,,could it be the MAF has finally died Its the original one?????
