Kendall1214
- Sep 30, 2014
Hi there y'all . I live in ks and just recently bought an 87 gn. Well fuel pump went bad which causing me to rebuild it.(new to gas side of power so dumb probably). But why I'm postin is i have a few things to ask, first I'm looking for a great launching bottom end and great top end cam what's your suggestion. Then it had a pt52 precision turbo on it which I thought ran pretty good, know of one better? And then it's got an alcohol system on it. But it back fires when hooked up so I unhooked it... Was wondering what kind of alcohol it takes? Smells like rubbing alcohol. Is that right? Or should it be methonol . My truck (dodge diesel) I mix methonol and water...do these cars as well? If so what's mixture ratios? Some things done on it from what i was told is heavy springs port and polished ground valves n guides LS1 MAFS and upgraded intercooler (think he said power stroke idr), external oil and trans cooler stainless steel lines, cold are intake 60# injectors fiberglass hood and nitto drag radials. Pt52 precision turbo 3 inch exhaust with a dump pipe. Comp cam..(not sure the size) fully built transmission deep oil pan and i think he said 3k stall converter, which don't really feel that unless babying it! And a turbo tweak chip! It ended up 21psi boost... If that helps any. Sorry if I'm being a pain just new to the gas high horsepower side of stuff! Any other suggestions would be great thanks! Oh and it's got air bags but they Aren't on the car yet!
