heads gascket question
tybob
hi i just buy a tta today whit a blow off heads gascket ! it is the same as a tr's
i just ask to order the parts before i remove everything :cool: thanks
if its stock ..yes same as the gn's
if not stock you may want to wait to see whats in there first
also going to need an intake pan gasket (felpro MS 90633 )
and if head bolts are stock or your unsure you'll need new head bolts and teflon thread sealer
if it was a stock gasket and it blew into the valley youll also want to drop the oil pan clean it out and clean or replace the oil pickup of all the graphite fibers
so add a pan gasket and an oil pickup to your list
hopefully it didnt mix green antifreeze in with the oil or youll be doing the bearings soon too
btw dropping the pan on those TTA's is alotta fun , youll need to raise the motor
thanks guys ,
only a heads gascket on the intake side ,no antifreeze in oil and all stock for the moment :biggrin: alky in the summer julio :D
robert from quebec
Graphite goes into oil and can clog oil pump pickup screen. Better check and be sure.
thanks guys ,
robert from quebec
julio do you have the parts number for arp studs ! do you recomand the cometik heads gascket ! i want run low-mid 11" i have a lot of good gn parts on the desk :biggrin: thanks:cool:
yeah ill check to make sure if thay have no grafite in oil pan is winter time ill remouve the engine and refresh them for the summer at the same time ....
