just plain john
El Camino a Go-Go!
- Feb 24, 2007
I changed my fuseblock to the GN unit. That will require me to use the GN headlight harness. Hi/lo, park and turn all look to be plug and play, but there's some connections that don't match. at either end of the harness around the lights there's a 2 pin weatherpack connector. Since it is a weatherpack connection, I assume it's some kind of sensor circuit, but I really am just guessing. M
oving up to the firewall, theres a single tan/white wire that looks like it is pushed on. This connection exists in my El harness, but I don't know where it goes. There's a 2 wire connection (yellow and violet) and a four pin connector (yellow wire jumps from the 2 wire plug to the 4 wire). My donor vehicle had cruise, but the wire lays out like the 2 wire connector should go to the wiper motor but the fitting is different, although still 2 wire. I'd also appreciate some guidance on routing the harness around the header panel.
