f117v6
- Oct 22, 2006
Will a leaking HG cause a lean condition? Went to track did three runs powerlogger running everything looked ok o2s afr etc. Car idled a little weird in pits so loaded up took it home and # 3 spark plug ground strap was gone Car had been running strong before , the track passes but if that gasket went would that cause my one cylinder lean condition. I have taken engine apart to short block yes HG was leaking not the worst i have seen and it was #3. The rest of the pistons looked fine {normal}. I had injectors sent to caspers ele. they where good.Trying to diagnose problem so there isnt a repeat . P.S Wanted title to say lean /rich couldnt edit that
