i believe it is that the cam sensor is not at the 25 degree requirement, my reason is that i have tried several replacement things, MAF sensor is good, coil pack is good, new plugs wires, and other general maintenance things have been done, which lead me to believe it might have been a camposition sensor, so i replaced it, this did not solve the problem, however i noticed that when the sensor was unplugged, the car ran fine and good as could be expected, but when pluged back in the stubling occured, always at the same RPM range of between 14-22 hundred rpms, would the caspers cam sensor be a good idea to invest in, as it allows the sensor to be rotated to the proper setting....thanks guys
--Jason
--Jason
