You need SOME angle at each end ,recommended to be equal at each end ,a minimum 1/2 degree at each u-joint and no more than 3 degrees...less is better.It will run out of these specs but may vibrate or wear prematurely, it is usually not that critical on a car unless lifted or lowered a lot.
hm
