Turbo__Tim
One heck of a Tim!
- May 25, 2001
My main question is this: What timing are you running. I tried to stay with 21* but cranking the timing to 25* really allows me to chew up the gas.
I'm staying with 94 sunoco.....
I don't think the cylinder temps are hot enough even yet. Adding a tiny bit of alchy seems to bog the engine somewhat. Right now the egt's are at 1325* at 75 MPH, and the 0-2's are at .830 at the same Mph.
I would like to hear from you guys that are running alum. heads to get an idea as to what timing you are running.
Especially those of you that are running pump gas and alchy.
I'm at 25* timing now, 19 psi. No knock without alchy.
I'd like to keep the boost at 19*. I'd like to add a little alchy, but it boggs the engine a bit. I'm undecided whether to add timing, or reduce the fuel input to aid the alchy injection.
I'm thinking of going to 27-29* timing. With alchy, of course......
Am I nuts? Is anyone running this high of timing with pump gas, and alchy?
