Grille springs & filler panel
rgs455
Need grille return springs and the filler panel that goes behind the grille which directs air to the radiator.
I have 3 or 4 sets of grill springs $12 shipped set. I think I have the center filler as well, I'll check and get back to you today.
Ok, if you are referring to the center bumper filler that mounts to the bumper reinforcement under the grill with 4 screws I have that. If you are referring to the black plastic piece that is riveted onto the botom of the grill I have that too. Either way grill springs and filler $30 shipped.
I'll go check tomorrow. I believe this piece is "U" shaped and attaches to the lower part of the grille and the front lower section of the core support. It basically encloses the area behind the grille to force air through the radiator.
