Im gonna have the pan off to re-torque the valvebody bolts due to a problem with delayed upshifts. While im in there, I wanna check the govenor springs and check balls. Is it ok to re-use the govenor housing gasket or could it cause problems?
Thanks for the responses people and thank you Greg for the offer on the gasket. I also have a second one that been used once and its not torn so I should be ok. Ill keep ya in mind though.
