I saw where the turbo is stock, but what about the rest of the drivetrain?
The engine was rebuilt .030 pistons,polished the crank and installed new bearings. new oil pump, timimg chain ect. The heads where cleaned up in the pockets and blended the bowls. camshaft is flat tapped replacement with lifters 208/208 @ .050 valve lift is .448 int&ext centerline is 110 int. 112 ext. Transmission is stock rebuild with stock replacement torque convertor. I put 42.5 # injectors in it& a chip for those injectors. This is a grear base if you want to modify or just leave it alone. When i had it tuned it made 267 hp to the rear wheels @ 15# boost. If you need any more info just call me I'm not on the computer that much. Thanks, John
