ALL ITEMS SOLD!!!!!!
I am doing a full rebuild on my motor to strengthen things up for my new setup and would like to sell off my older stuff to help with the funds. I'm not trying to get rich off of anyone here, so I hope you can recognize that I have already priced these items decently well.
-Precision TE64 turbo - $400
-66mm comp. wheel with .60 A/R Garrett comp. housing
-65mm turbine wheel with .63 A/R Precision housing
(two turbine housing bolts are sheared, but it's an easy fix if needed, but can be run as is just fine. I acquired the turbo in this condition and had no problem with it.)
-Siemens Deka 80lb. injectors - PENDING
-these were flowmatched before going in from the previous owner and have worked flawlessly for me
-TT 5.7 chip - $30
-22*/20* 25+psi on 66mm turbo/80lb. injectors on 93/alky
Next I have an LS1 MAF sensor and Translator with an intake pipe. The MAF sensor I purchased second hand from a member on this page and it's in good working condition. The MAF translator I purchased from G Body parts about 4 months ago. Also works perfectly. The intake pipe has a black smudge on the bottom about the size of a quarter.
SOLD!!!!
message me with questions. I'll have a few other items up shortly.
-TT 5.7 chip - $30
SOLD!!!!
