nonova0074
- Aug 13, 2006
Will the wheels stick out or do you really need flares
I have 2 sets of gtas, the thing is they aren't perfect. So I am either going to get the repros or get my set of nondimpled redone.
ok whats your back spacing, cause I have gta's with spacers and have been thinking about calling brian from gbody to have my wheels redone to gnx spec so i dont need spacers and the tires clear. I just dont want the tires to stick out like a 4x4
Thanks Matt this is the info I have been looking for. Who did your rims, I have 4 non dimpled rims that I would like to have redone this winter. I also have a set of dimpled wheels that I am gonig to put on there for the winter. I have seen the ci wheels the look ok, but I prefer a highly polished inside and out with a powder coated mesh center. And like I said I don't want spacers. Even with a 255 on a stock from or ci repro you still need a 1/8 space depending on what brand tire it is. There a new 255 dr that I would like to try out, seeing after I paint it I am only got to drive it on nice days.Check out the pics in my gallery. Rears are 3 1/2" bs with 255/50/16 and front are 4 1/8" bs with 245/50/16. True GNX have -23 offset rears which i believe equates to about 3 7/16" bs and fronts are -15 which equates to about 3 15/16" bs. so mine are pretty close, alot closer than GTA wheels at 4 1/2" bs. Never liked the way the front GTA didn't quite fill the rear wheelwell.
No issues and they dont stick out like a 4x4
This is on an 87 with stock ride height so your results may vary.
HTH
Matt
CI has the set of 4 $700 plus shipping and they have 20percent off this month. The right back spacing all 4 the same size wheels. It's in one deal. You don't have to ask for 4 fronts. Then there are lots of deals on eBay for the center caps for $60 . Hope this helps
