Asc gnx dash cluster. All new stewart warner gauges.Includes new sending units and speedo cable. Caspers plug and play harness. Speedo modified for gm vss. Will need final fitment to your dash. $1500 FIRM
FYI, you've got the pink/black wire terminal on a ground post of the tach bracket...doesn't go there. It goes on the brass stud next to the lights (instructions spell this out). If you ground the pink/black wire, pop goes the fuse.
Caspers instructions show it just the way it is. What are you reading that says different? Caspers instructions are posted on their web site. I used what they sent me to wire this one.Under the tach bracket it does say POS on the housing. So? Jack
Instructions read:
Attach Pink/Black positive feed ring terminals in “daisy-chain” fashion as follows, starting from the C1 bulkhead
connector: Tachometer “POS”
Fuel Level Gage “I”
WaterTemp Gage “I”
Oil Pressure Gage “I”"
The picture seems to show different...pink/black is attached to the bracket. DO NOT attach the wire to that bracket; use the written instructions.The picture is not correct.
If you leave the pink/black terminal on the bracket, the dash won't work.
