HELP - need some advice . My GN has a problem. When I accelerate, car bogs out at 70 mph. My 87 has less than 15,000 original miles. Local Buick dealer tested fuel pump--it was bad.
Everything is stock original except for NOS GNX dash installed at 14,000 miles. I had Buick replace fuel pump with the "halbro" high performance fuel pump, and also had a billet aluminum fuel pressure regulator added. I also bought the "hot wire" kit to fuel pump but didn't have it installed due to Lackamoola. ($$)
Does Halbro fuel pump work better with hot wire? Or is there more to my problem?? ie... spark plug or something else.
Also should mention, car only goes about 400 miles/year and it usually has a full tank of gas that isn't emptied or stabilized.
I'd appreciate some advice as to what I should do next.
thanks,
JERRY
thanks,
JERRY
