N Noopz1991 Member Joined Mar 22, 2012 May 13, 2015 #1 I wanna put a 87 GN drive train in my 83 T-Type, is it hard to do? Do I just need the engine harness and ecm, or is there more to it.
etriebe Active Member Joined Dec 2, 2008 May 13, 2015 #2 A bit more I'm in the middle of an 83 regal now. The headlight harness needs to be changed and also the dash harness. If it was an 84 it would be plug and play. http://www.turbobuick.com/forums/threads/hybrid-build-my-new-1983-regal-estate-wagon.407759/
N Noopz1991 Member Joined Mar 22, 2012 May 13, 2015 #3 I have a 86 regal dash and wiring in my car now. I switched the 83 wiring right when I got the car.
N Noopz1991 Member Joined Mar 22, 2012 May 13, 2015 #4 The 86 I took it from is jus a plan regal it wasn't the ttype
etriebe Active Member Joined Dec 2, 2008 May 13, 2015 #5 That should be fine then, all my wiring is from an 86 cutlass sedan
N Noopz1991 Member Joined Mar 22, 2012 May 13, 2015 #6 Do I still gotta change the headlight harness. I stripped my 86 I bought down n took the whole wiring from front to back
etriebe Active Member Joined Dec 2, 2008 May 13, 2015 #7 Yeah the headlight harness won't plug into the back of the fuseblock or mate with the engine harness
