PM or e-mail with any questions.
PayPal accepted. Send to bigoilman@yahoo.com
My 1936 Chevy Street Rod project and 2003 Avalanche are also for sale.
Here's the list...
2 109 blocks (one standard, one .030 over) $300 and $100 respectively
2 turbo cranks $125 each
Champion Iron heads (1 is brand new, never run) - $700
TE44 with polished housing - Sold
9" K&N filter with polished MAF pipe (shine is NOT good) - $10
Hemco Upper Plenum Race version - $100 Sold
Stock Upper Plenum - $30
Spearco Intercooler (the kind they put in the hot-air conversion kits) - $100
3.5" MAF and MAF Translator - $150 Pending
T&D roller rockers - $150 - Sold
.030 Forged Pistons (TRWs)on 2 dot rods - $200
.030 Forged Pistons (TRWs) on 2 dot rods - $100 (these got dinged in shipping a little bit I can send some close-up pics)
5 – stock Buick TR pistons and 2 dot rods - $75
Gauge pods (center console (SOLD) and single A-Pillar (Available) $ 15 each
ECM - $75
Powder coated relay bracket (the one that goes on the firewall) - $15
50# injectors and chips for them – Sold
ATR PITBULL chip for #52 injectors - $25
Casper's Electronics LC2 wiring harness for hybrid/race installations - $375
Casper’s 14 Gauge injector harness - $75
Ported stock intake - $250
TCI 2004R tranny - $400
12" 2800 stall convertor - $150
Stock Fuel rail - $25
Adj. FPR (billet) - $65
Crank Sensor - $20
Cam Sensor - $40
TB Cable Bracket - $20 (SOLD)
Stock up pipe - $15
3” SS Downpipe (parts) This is a 3” BGC DP w/o the elbow. Great for building your own DP - $100
Ported Stock DP elbow - $25
Stock DP - $15
Stock Crossover pipe - $10
Stock Crossover pipe with Deltagate flange - $10
3” “Stubby” DP elbow with wastegate - $100
Front engine cover - $25
P/S Pump and pulley - $30
Racetronix Fans (New)
Stock Headers – w/crossover - $100
Ported stock TB - $40
Turbo mounting bracket - $40
Accessory mounting bracket - $75 (SOLD)
Starter - $10
Flex Plate - $20
Trans. Mount. (aftermarket for 2004R –Urethane) - $10
Harmonic Balancer - $20 (SOLD)
Walbro 340 fuel pump - $35
Billet main caps (centers)– $100
Stock I/C fan - $20
Oil Pan - $35
Turbo heat shield - $25
Coilpack and ignition module - $100
Billet aluminum vacuum block for vacuum brake conversion - $20
Casper’s silver-face knock gauge - $30 (SOLD)
Autometer Pro-Comp Ultra-lite 0-35 Boost gauge - $20 (SOLD)
Autometer Pro-Comp Ultra-lite gauges - $350 (will not part out at this time)
3-3/8” Speedo
3-3/8” Tach
2-5/8” H20 Temp
2-5/8” Oil Pressure
2-5/8” Volt Meter
2-5/8” Fuel Level
Racetronix Dual Fan harness NEW – $50
Racetronix PnP Fuel Pump Hotwire harness with ground upgrades NEW - $35
Dual Fans (the one’s GBodyParts.com sells) – NEW - $100
Turbolink software v.2.1 – $50
Casper’s Cam sensor tool – $20
Here's the list...
ECM - $75
Crank Sensor - $20
Cam Sensor - $40
Stock up pipe - $15
Stock DP - $15
Starter - $10
Flex Plate - $20
Stock I/C fan - $20
Oil Pan - $35
3-3/8” Speedo
3-3/8” Tach
2-5/8” H20 Temp
2-5/8” Oil Pressure
2-5/8” Volt Meter
2-5/8” Fuel Level
