F
Four-Four-Two
Guest
I'm kinda all over the place on this one, so please bear with me.
My car is set at the stock boost levels right now, which I though was 13psi. Next week, I am installing a Hooker 2.5" exhaust with a test pipe. I have heard that you pick up a few extra pounds of boost when you install the system over the restrictive stock one. Am I going to see say 16 or 17 pounds of boost, or will the un-modified wastegate keep it at 13?
Also, I am going to get a Thrasher 92 chip for the street. If I get it set for 17 psi, will I have to adjust the wastegate rod to see 17 psi, or does the chip do that automatically?
