valvoline dino 75w90
x2 with a bottle of friction modifier.........
Why would someone want to add a friction modifer that will allow more slip in a posi unit?
GM used this in earlier years, but in the 80's it was not recommended for the factory limited slip rears.
So this is not synthetic oil correct.on any of the oil brands everyone has talked about ?
From what I understand, It's not a friction modifier but an additive that keeps the gear oil from foaming, an anti-foam agent.Why would someone want to add a friction modifer that will allow more slip in a posi unit?
This is what I've used for 22 years because it was the only thing that worked back then. I tried the additives and synthetics. This was the only thing that worked and still does. I think it was because my posi was so tight. My posi works every bit as good today as it did 22 years ago.What do u guys recommend for gear oil for the rear end.?(STOCK REAR END).just did axle seals and new ta cover.
thanx for the input.
