I have an 87 Turbo T that I am starting to bring back to life, and I have an 84 GN that I have for parts. I have to swap the 84 dash into the 87 as a monster tach was drywall screwed to it. Anyhow, the digital dash on the 87 is not working, and I thought about swapping the 84 speedo cluster in at the same time. I understand that I would have to transfer the dash harness as well, since they are not the same...is anything else required? Are the dash harness' the same between the years otherwise?
I have also heard that I may have to swap the fuel tanks sending unit, although I do not see different part numbers sending units listed. Doesn't matter as I am dropping the tank for a new fuel pump anyhow, just need to know what to get.
Thanks in advance!
Thanks in advance!
