Gas tank sound deadner pad for 1987 GN
miked
Need an NOS or like new Gas tank sound deadner pad. My new GM tank did not come with one, part no longer available from GM. The pad is located under the tank right below where the fuel pump sits. Thank you, Mike D.
If you cant locate one, try getting a piece of dynomat and cutting it into strips as this will be the closest you will get to the original tar strips that GM used.
